This procedure only applies to the VSP 7400 Series.
Ensure that you enable DvR on the node.
Perform this procedure to view all remote DvR routes on a Controller or a Leaf node.
The Controller node displays all the IP subnet routes configured for that DvR domain. A Leaf node displays all IP subnet routes learned from the Controller(s) for the Layer 2 VSNs in the DvR Domain. It also displays the Host Routes (ARPs) learned from other DvR enabled nodes.
  1. In the navigation pane, expand Configuration > Fabric.
  2. Select DVR Remote.
  3. Select the Database tab.
  4. Optional: To filter the rows based on the specific criteria, select Filter.
Database Field Descriptions
Use the data in the following table to use the Database tab.
Name
Description
DestIpAddrType
Specifies the address type of the IPv4 destination address of the DvR database entry.
DestIpAddr
Specifies the IPv4 destination address of the DvR database entry.
DestMask
Specifies the destination mask of the DvR database entry.
L3Isid
Specifies the Layer 3 I-SID of the DvR database entry.
EcmpIndex
Specifies the ECMP index for the DvR database entry.
NextHop
Specifies the MAC address of the next hop BEB, in the DvR database entry.
L2Isid
Specifies the Layer 2 I-SID of the DvR database entry.
VrfId
Specifies the VRF ID for the DvR database entry.
OutgoingInterface
Specifies the outgoing interface (port or MLT) of the DvR database entry.
SpbCost
Specifies the SPB cost of the DvR database entry.
PrefixCost
Specifies the prefix cost of the DvR database entry.
NextHopName
Specifies the host name of the next hop BEB, in the DvR database table entry.
Age
Specifies the uptime since creation of the DvR database table entry.
